Tenho um disco I de 95 5portas. Neste momento tem uk kit de molas com mais 2'' e amortecedores. Qual a medida de pneus que posso montar sem ter de cortar nada?
estava a pensar nuns 265/70 R16, é possível?
Medida Pneus max Aplicar no Disco I
fernando_castro
- Land Rover: Serie III 109 Pickup Diesel 1977
Disco II TD5 7lug cx Auto 2001
ex Disco 300 TDI 5p 1995
ex Disco 200 TDI 3P 1994 - Sócio LCP: 842
Sócion.º842
Viva "fernando_castro"
aí vaí:
Tire fitment guide:
Discovery
235/70-16: Stock tire size.
205/80-16: Stock size in many other countries. same height as 235/70-16.
255/65-16: same height as stock
225/75-16: little taller than stock
245/70-16: little taller and wider than the stock size. reportedly, no need for lift, just minor trimming to fit those tires.
245/75-16: popular size for OME suspension lifted vehicles. require slight trimming on the rear wheel well fender, and may also call for adjustment on the steering bumpstops.
215/85-16: same height as 245/75-16. but narrower. seems to be preferred for the snow and mud.
265/70-16: about as tall as 245/75-16, but wider. will require more trimming and steering bump stops adjustments along with taller bump stops over the rear axle.
265/75-16: almost 32" tall. Same as stock NAS D90 tires. Will require even more trimming.
235/85-16: same height as 265/75-16 but narrower. And seems to be the most popular size with OME lift.
255/85-16: about 33" tall...very few people have fitted this size. Lots of butchering for this one.
285/75-16: about 33" also... but very very wide.
aí vaí:
Tire fitment guide:
Discovery
mcsarria
Caro colega.
No meu primeiro disco que tive era um 200 de 92 e meti a molas mais 2 polgadas e tive os BF Mud 245/75/16 e ficou ou xou.Mas depois comecei a querer mais e meti uns tacos de 3cm e os BF Mud 265/75/16 e nunca ou quase nunca tocava.
Se queres o bicho mais para mato opta pelos maiores, caso contrario os 245 com as jantes mais puxadinhas para fora mas sem sair da cava fica muito bom.
Força ai...
Força ai...
Sempre em frente é que é o caminho...
OU NÃO...
OU NÃO...
